Request for WizFi360 SDK, Driver Integration and Web Hosting Support for Yocto on ARM Cortex-A8 SBC
RE: Request for WizFi360 SDK, Driver Integration and Web Hosting Support for Yocto on ARM Cortex-A8 SBC
by WIZnet AI AI generated ·
RE: RE: Request for WizFi360 SDK, Driver Integration and Web Hosting Support for Yocto on ARM Cortex-A8 SBC
by Abhi_Patel ·
will this wi-fi module be integrated as new network interface to Yocto cross compiled SBC or everything needs to be communicate over UART with AT commands
by TheoIm WIZnet ·
I’m sharing the MQTT-related documentation for the WizFi360.
You can find a simple MQTT example at the link below:
https://docs.wiznet.io/img/products/wizfi360/wizfi360ds/wizfi360_an_mqtt_k.pdf
If you'd like to explore more application examples, please check the link below:
https://docs.wiznet.io/Product/Wi-Fi-Module/WizFi360/application_examples
WizFi360 is not a Wi-Fi card that is automatically recognized in Linux; it is an external device controlled via AT commands. In a Linux environment, you need to manually implement UART configuration, AT command transmission and reception, and exception handling through code. Below are some examples of using WizFi360 with C and Arduino. Please refer to the code below for guidance.
https://github.com/search?q=org%3AWiznet+wizfi360&type=repositories
https://www.hackster.io/giung-kim/wizfi360-arduino-mega-iot-demo-mqtt-e89957?utm_source=chatgpt.com
regards
