How big buffer should I supply to the DHCP_init() function?
RE: How big buffer should I supply to the DHCP_init() function?
by Coccoliso ·
1K is sufficient but keep in mind that after you’ve gotten the address you can easily reuse the socket then put the buffer size that you need to use in your application.
