Clarification of overflow spec. of read/write flags of input buffer.
- C/C++
- W5500
RE: Clarification of overflow spec. of read/write flags of input buffer.
by Lihan__ WIZnet ·
The socket buffer pointers in the W5500 (such as Sn_RX_RD and Sn_TX_WR) are 16-bit registers. These registers are not tied directly to the physical buffer size (which is up to 16KB), but instead represent a logical address space ranging from 0x0000 to 0xFFFF (64KB).
The actual buffer size is configured by Sn_RXBUF_SIZE, and can be 2KB, 4KB, 8KB, or 16KB. Regardless of the buffer size, the pointer always increments within the 16-bit range and wraps back to 0x0000 after 0xFFFF.
Internally, the hardware maps the pointer into the real buffer by applying a modulo operation with the configured buffer size. For example, with 2KB the physical address is calculated as
pointer % 0x0800, with 4KB aspointer % 0x1000, with 8KB aspointer % 0x2000, and with 16KB aspointer % 0x4000.Therefore, the overflow mentioned in the datasheet does not mean the buffer is physically larger than 16KB. It simply describes the circular buffer mechanism where the 16-bit pointer naturally rolls over. For smaller buffer sizes, the higher bits of the pointer are ignored and only the lower bits are used to index the actual buffer.
As a developer, you can safely use the pointer values as provided; the W5500 ensures they always map correctly into the actual buffer space.
