WIZ550io Using LabView
RE: WIZ550io Using LabView
Yes, you can. Read sensor data and then send the data to WIZ550io.
by Coccoliso ·
Hello Franci,
you must make sure to work with SPI in Variable Length Date Mode (VDM) and act with 2 separate CS to select the SPI device and communicate through a bit banging protocol.
The Wiz550io can also work in FDM (fixed length data mode), but that will not work with other SPI devices because it does not release the MISO ( see 2.3 W5500 datasheet section ).
