Wiz550io no socket control
IO Modules
IO Modules
RE: Wiz550io no socket control
Destination port and IP can be read after TCP connection is established.
First, try to connect and then check registers.
by outlaw314 ·
Thank you. Now I understand. So I’m able to see registers now but still can’t seem to connect like I did before. I’m getting a timeout flag on the socket. My firewall shows no packets coming from the switch. I suspect the issue is with something other than the Wiz550io now, but in case I’m missing something obvious again, here are the settings I’m using.
Subnet mask: 255.255.255.0
Gateway IP: 192.168.2.1
Source IP: 192.168.2.3
Socket 0
TCP
IP address: 192.168.2.2
Source/Destination port: 31415
Everything else uses default values set by hardware reset.
by outlaw314 ·
Ignore that last post. I just connected. I suspect I tried to connect too soon after giving the “open” command. Thanks again.
