WIZ107SR - manual connect and disconnect from Host
RE: WIZ107SR - manual connect and disconnect from Host
by jameskim ·
I’m sorry that WIZ107SR doesn’t support manual connection.
However, even I don’t know what your exact intention is, I recommend you use “TCP mixed” mode.
In “TCP mixed” mode, WIZ107SR waits for connection request from Peer system and it tries to connect to its Peer system when it receives any data from its serial port.
So you can emulate manual connection by sending any data to serial port of WIZ107SR.
I hope this function is helpful to you.
James.
by tgreczan ·
Thanks for answer.
I’ve just realized, when module is entering into command mode is disconnecting from host.
So I will use it.
