MikroC Compiler problems with W5500_CortexM3_Firmware
RE: MikroC Compiler problems with W5500_CortexM3_Firmware
by Christian ·
Solved found my user error
by Christian ·
Okay they really were not declared and that’s because having a look at the specification of the STM32F2xx Chip these is done different.
So not really solved the problem at this stage but understand now where these needs to be done.
Have found a helpful document form STM:
Migrating a microcontroller application from STM32F1 to STM32F2 series
st.com/st-web-ui/static/acti … 033267.pdf
But as I am using MicroC as development environment and facing new problems.
Therefore will still need help. Is anybody here using MikroC as well?
If not can you please tell me what software are you using?
Some problems with MikroC are for example:
Best regards
Christian
