Problems with io6Library
RE: Problems with io6Library
by taylor ·
The CW_GET_ID means static strings of
_WIZCHIP_ID_defined in wizchip_config.h.There are examples of W6100EVB. This is Loopback one of W6100 examples.
by phischl ·
Thanks taylor for your reply.
I included the wizchip_conf.h but I can’t see any SPI activity on the SPI pins.
Thanks for the link, I will try one of the examples.
by phischl ·
Unfortunately I didn’t manage to get the loopback example to run.
The output in the terminal looks like this:
I copied everything from the main file into my main.c file and also the function calls:
I attached some screenshots of the SPI communication, does this look right?
Thanks for your help.
by phischl ·
The output in my serial monitor looks like this:
I am not sure why the IP address can’t be set.
Does someone know where the problem is or point me in the right direction?
Thank you!
by phischl ·
I found the problem:
I am using a 16bit MCU while the library is written for a 32bit MCU.
In the w6100.h file I had to add some type casting for the address registers:
#define SIPR (W6100_IO_BASE + ( (uint32_t) 0x4138 << 8) + WIZCHIP_CREG_BLOCK)
Now I can read out chip ID, network parameters and also the loopback example works.
