Startup problem
RE: Startup problem
by petervk ·
Thanks for your fast answer.
The another reset are the reset pins on my print. These are connected to the reset pin of the W5300. The problem occurs also when i make the reset pin low for 1 second or when i power off the print for one minute. When power on I initialize the chip by first make the MR = (1 << 7); reset bit high. Afther that I wait for 300ms. The problem is difficult because it occurs not every startup cycle. Can someone please help?
Thanks in advance.
Peter
RE: Startup problem
by petervk ·
Thanks for your answer. I e-mailed you the schematics. The reset pin of the W5300 is connected to the reset pin of the microcontroller and the external reset pins on the print.
So I have a hardware reset and in my W5300_init() I use one software reset. The W5300 is used for a PLC(Programmable logic controller) controller. The PLC controller controls a packaging machine. This machine must be powered on and off without any problems.
The PLC controller is in the developing phase. So I use the hardware reset pins +/- 10 times a day. About 1 in the 20 resets the W5300 is not starting and the link led blinks with a frequency of 1 Hz.
Thanks in advance.
RE: Startup problem
by mboehmer ·
Congratulations. I had the same problem with several WizWeb200 modules, which were already patched to allow the ATmega128 to operate the W5300 /RST line by GPIO (using an RC combination on /RST is a really stupid idea if you have slowly rising power supply).
Nevertheless, especially after a system reset one module or the other might end up in such a state… linkup, linkdown, linkup, linkdown… forever. Usually it happens after a remote firmware update, but not limited to that (main system is still operational, but TCP/IP access is blocked, which will lead the main system to notify me as some nodes did disappear).
According to Wiznet this problem is not known, and they never heard of it… several requests to WizNet support didn’t give any satisfying answer (it is, of course, a really hard to track down problem, as it cant be easily reproduced).
I haven’t found a real fix for it. Seems to me that the W5300 PLL screws up and doesnt operate properly, so the whole chip is locked in a really weird state.
My best fix (so far) is to monitor the LINK signal (from LNKLED, as there is no PHY status register). In case too many linkup/linkdown changes per minute are monitored, I do a full system restart and hope the best for it.
I think users of W5300 need to live with that feature.
Michael
RE: Startup problem
by bboyes ·
It’s not clear in the w5100 or w5200 data sheets if PLOCK also applies to software reset? I can do a test to find out, but does anyone know? Same question for w5500.
RE: Startup problem
Datasheet says:
[quote]S/W Reset
If this bit is ‘1’, internal register will be initialized. It will be automatically cleared after reset.[/quote]
The indication of the software reset completion is RST bit becoming 0. No need to wait for 10, 150 ms or whatever.
Regarding initial problem with reset. Three things I would consider:
RE: Startup problem
by jshef ·
I have been working with these microchips(W5300, W5200) for many years. These crystals are very critical to temperature and soldering time. I think Wiznet knows about this problem. If you overheat the microcircuit during soldering, the microcircuit starts only if it heats up. The problem is solved only by replacing the chip. In some parties to behave in this way 10% of the chips. The problem is that you never know at what temperature the modules are soldered.
How to detect a bad chip:
RE: RE: Startup problem
My empirical studies show very similar findings. I had to replace 30 chips recently because I was hand soldering them at 380 C. Now I solder at 305 C. Thanks for the way to identify bad chip!
RE: Startup problem
by jshef ·
Евгений, я Вам советую использовать пасту Sn42, Be 58 и паять эти чипы не более 225 град.
Иначе будут постоянные проблемы со стартом. Вы работали с чипом W5500 промышленно? Я только начинаю переход н эти чипы. Не хотелось бы иметь эти проблемы.
RE: Startup problem
by Vasily Kharitonov ·
It looks like we have the same problem in our production.
We use W5300 chips in production. It seems that about 5%-10% of boards has issue with W5300.
Issue is hard to detect because it appears only sometimes.
Corrupted units has irregular connectivity issue. Approximately once per 10-50 connection link is not established. The problem goes away as soon as we replace W5300 manually.
We would keep it as it is, but we have big array of devices connected through W5300. Each time we turn array on, some random devices are not linked. We have to replace chip or board to fix the problem. Once chip is replaced, problem never comes again.
Every corrupted unit has approximately stable issue rate:
For example one corrupted unit can have connectivity issue once per 5-7 times
another corrupted unit could have the same issue once per 15-20 times
Functional boards were tested for connections more then 200 times without any errors.
We put a lot of time to research an issue and it still seems to be out of control. So we just decided to replace chip on 5% of the boards manually.
But last batch of boards, we got from manufacturer has much more corrupted boards (about 30%) with the same issue.
We might go to different Ethernet solution in next revisions if we can not find how to fix that.
RE: Startup problem
Thank you for reply. We came to the same solution and tried to monitor LNK led. This partially has fixed the problem. But sometimes we have units, which gives fake link signal. Though more rare.
