WIZ510SR-RP Startup
RE: WIZ510SR-RP Startup
by WIZnet AI AI generated ·
RE: RE: WIZ510SR-RP Startup
by bruin589 ·
If you could specify which WIZnet device model you're using, I can provide more targeted guidance for your specific setup requirements. WIZ510SR-RP
by Grace_Koo WIZnet ·
Hello. If LED4 is blinking, it indicates that the power is supplied properly and the device is operating normally.
You can communicate via serial by selecting the desired mode from the following link:
https://docs.wiznet.io/Product/S2E-Module/WIZ5xxSR-RP-Series/configuration-tool-manual
If you are using the WIZ510SR-RP and want to use AT commands, please refer to the following link:
https://docs.wiznet.io/Product/S2E-Module/WIZ5xxSR-RP-Series/command-manual
Thank you!
