Wiz110sr How to reset to factory?
RE: Wiz110sr How to reset to factory?
by felix ·
Hello safe1234,
the method I am using is the following: If I notice I have to reset a module and it’s running I connect to the serial port. Then I just shorten both pins of JP1 (with a scissor or a screwdriver or something you can firmly press on both holes of JP1) and power cycle the module. Then I can see on the serial console that the module has been reset to factory default. I release the screwdriver/scissor/tool and power cycle the module again. it is then booting with the factory defaults. What did you use to shorten the pins of JP1?
Best regards,
Felix
