Wiz107SR garbage data (RS232) {SOLVED}
RE: Wiz107SR garbage data (RS232) {SOLVED}
by rikotech ·
Thank you for reply!
The purpose I use it is exactly to debug my serial connection, hence I was able to see it doesnt work. Nonetheless I unchecked the debug message, afterward I sent/received a single character data trough Device Terminal Program 1.0 and I still get corrupted data.
by rikotech ·
Thank you midnightcow!
I tried what you suggested. The result was [quote]LGSEG:CONNECTED[/quote]. Ok, so the device seems to work well in “stand alone mode”.
Then where am I wrong? I am pretty much sure it is on BAUD rate. Anyway, this is my test scheme:
I am waiting for my oscilloscope to return from the service so I can determine tha actual BAUD rate.
A question is if the WIZ107SR serial port is TTL or RS232?
If the data being transmited is inverted or not?
Dont get me wrong, I have read the datasheet, but I have no idea what might be wrong in this case.
WIZ107SR was released ‘TTL’ and ‘RS-232’ version both.
if you can find U2 ‘RS-232 transceiver’ (refer to WIZ107SR partlist) on your module, you have WIZ107SR RS-232 version and if not, it’s TTL version.
(Please check your board revision first. before revision 1.1 was released RS-232 version only.)
WIZ107SR RS-232 version is no need to use ‘TTL - RS-232 transceiver’ (like MAX3232).
if you want to use DB-9 port, please connect the port directly on the module.
by rikotech ·
Thank you so much Guys!
Yes it has!
The problem was I put MAX3232 after the module which has already such.
Now everything work perfect.
Thank you again!
