Wiznet 110SR - need help with configuration, please
RE: Wiznet 110SR - need help with configuration, please
by ywkwon ·
Well… Check the other device that has same IP address as “192.168.1.5”
I guess the VSP tring to connect another device that has same IP address.
Your setting is fine.
by MizuSVK ·
Hi, thanks for the reply, i was connected via ethernet cable directly to 110sr (computer to wiznet), there were no other devices. Ping to 110sr responded. Any other ideas how to run this setup?
by ywkwon ·
It was Lunar New Year holiday in South Korea.
So, I’m late to reply.
Turn off all firewall of your PC.
I guess your firewall will defend connection.
If you face same problem after turn off the firewall,
Check the connection using other TCP client program.
by MizuSVK ·
There is no firewall on machine from I want to connect.
What do you mean using other TCP client program ? to test if I can connect to virtual com port ?
Satel is using only proprietary software, and there is no other software I can connect to device with
When I am using USB to serial dongle, everything is working correctly.
