AT89S5253 SPI Problem
RE: AT89S5253 SPI Problem
by Seppel ·
I own a 20 MHz 2-channel analog scope,
but don’t think that I can make good enough pictures of the waves.
What signals would you like to see? Sck vs. Mosi and CS vs. Sck?
Before I used hardeware SPI inside the 89S8253 with SD-Card, display and w5100, I used
only software SPI with an Atmel 89S82 and dicovered that I had to
adjust my SPI routine specially for the w5100. Although all components claim
to expect mode 0. And I programmed mode 0 for SD and display before I tried the w5100.
Since software SPI is quite slow it can’t be a real timing problem.
It is more a problem when each signal has to be asserted in general. (IMHO)
Hat do you think about it ? Can I contact Wiznet about this somehow?
Cheers, Roland
by Seppel ·
I use an Arduino Ethernet-Shield that has an inverter for /CS → SEN.
So the reqs of that AN should be met.
It’s a pity the shield also uses a resistor network for adjusting voltage
to 3.3V, but I have alread checked the voltage levels and waves, which seemed all right to me.
But I am going to check it again…
I used the 00 01 02 03 - scheme writing to the w5100 for debugging of the soft-SPI-routine.
Thanks, Roland
by Seppel ·
Hi again,
it took me some time , but now I know what went wrong.
I did not reset the W5100 correctly. Strange, it works via software SPI then but
gets the hiccups when I use Hardware SPI.
Thank you for your help!
