W5300 MACRAW Rx FIFO overflow condition
RE: W5300 MACRAW Rx FIFO overflow condition
by lr15 ·
Instead recved_size = recved_size – 2 – pack_size – 4 - 1(if received odd packet); should be done. Correct?
In your testing, what’s 4096? I guess I’ll rephrase my question! All my questions are on the condition when an overflow happens. So, “On overflow condition, after closing the FIFO, are all the packet read from the FIFO valid?” Can you test it by letting the FIFO overflow(REMAINING SPACE IN FIFO < (ALLOCATED FIFO SIZE - 1528)) and also add packets with odd bytes?
When you say W5300 doesn’t support flushing, you mean closing and reopening the socket will not clear(reset) and thus empty it’s FIFO’s? Which means the old data will be present even after closing and reopening the socket and I have to read the Sn_RX_FIFOR before starting the next reception?
I appreciate your response. Thanks!
by lr15 ·
/* calculate the size of remained data in internal RX memory*/
recved_size = recved_size – 2 – pack_size – 4;
Let’s say two odd packets were received back to back. 101 + 101.
Now the Sn_RX_RSR would be {2(packet info) + 101(data) + 1(dummy data) + 4 (crc) = 108} * 2 = 216
From the math, recved_size = recved_size – 2 – pack_size – 4; After processing the first packet, I’ll end up with recevied_size = 216 - 2 - 101 - 4 = 109. The received count should be 108.
I would subtract (read_cnt * 2) instead of pack_size in that equation.
It doesn’t make sense to me, perhaps I’m missing something here.
Quote from page 114
"Notice: In case that free buffer size of internal RX memory is smaller than the size of receiving
MAC RAW data, some parts of un-acceptable PACKET-INFO and DATA packet of the
MACRAW data can be saved in internal RX memory. This can cause the error in analyzing
PACKET-INFO (as shown in above code), and receiving correct MACRAW data. This
problem is more likely to happen when internal RX memory gets close full. This can be
solved by ignoring some loss of MACRAW data. "
Could you explain the above statement?
by lr15 ·
[quote=“lr15”]1. The following is from page 115 in w5300 datasheet(version 1.2.8)
Let’s say an odd packet was received - 101 bytes. Now the Sn_RX_RSR would be
Quote from page 114
by lr15 ·
Okay, I did some testing last couple days to handle the rx FIFO overflow condition in MACRAW mode.
When overflow happens, just closing and reopening the socket leads to bad packet info(the length of the received packet is more than 1514). I was expecting everything to be reset and just work fine but it is not. I guess this should be easily reproducible in your set up too.
Since closing and reopening failed, I decided to read the RX FIFO out as per the code in w5300 datasheet. This also gives bad packet info. Analyzing more into this, I see that the S0_RX_FIFOR shows one value before closing the socket and shows another after closing the socket. So I believe the S0_RX_FIFOR after closing the socket must be used to process the data.
Seems like some irrelevant data(perhaps from previous packet) is put in the rx fifo when overflow occurs. Even after closing the socket? Should I wait for sometime before reopening the socket/ after reopening the socket?
I’ll do more testing and post results in a few days. I’ll appreciate if you can confirm whether my testing results makes sense to you and you can reproduce it.
Thanks!
by lr15 ·
Okay, from what you have said I understand that packet_info bad means overflow has happened already before I could check for the condition(<1528). Now the FIFO data is definitely bad and I need to close and reopen the socket.
So, I’m going to close and reopen the socket on two instances.
There is definitely going to be a loss of data on FIFO overflow on the second condition. This is mainly because I’m not able to read the data out faster from the RX FIFO. But, loosing the already received data is bad. I think this should be in the errata even if its mentioned in the datasheet.
I appreciate your quick response midnightcow!
by lr15 ·
When overflow happens, the FIFO gets corrupted and it is identified when the packet_info is bad. Detecting corruption of the FIFO is based on packet_info. The problem is, there is no guarantee that when the overflow happens the packet_info would be always greater than 1514 bytes. It is just random bytes from the stream. So it could also be lesser than 1514 but wrong(bad).
So the user could be reading the corrupted FIFO since the packet info is less than 1514. This will eventually lead to bad packet_info and the user will detect overflow. But the previous packets read could be bad. So when working in MACRAW mode, CRC must always be used to ensure the packet is good.
