Wiz610wi serial to wifi issue
RE: Wiz610wi serial to wifi issue
by kaizen ·
Dear Francisco
If WizFi610wi module is normal, you can see it’s default SSID in your computer when only connect VCC(Pin9 or Pin10) and GND(Pin35).
This is check point for this problem.
by FranciscoPerez ·
Thanks for the info Kaizen.
Meter reads 140mA with only VCC and GND connected. Voltage prior to connecting the Wiz610wi module is 3.30v, and after installing it, drops to 2.72v.
Should I expect then that my wifi module is faulty?
Thank you very much,
Kind regards,
Francisco Pérez
by kaizen ·
Hi
If WIZ610wi module is normal, It has to have more than 380mA and less than 480mA when only connect VCC and GND.
But I think your module doesn’t have this current. So you would better connect our distributor.
For detailed information, refer this URL
[url]http://wiznet.co.kr/sub_modules/en/aboutus/contactus.asp[/url]
