Invoke a URL
RE: Invoke a URL
Hi koldiodo,
I’m sorry but your question is not well understood.
would you please explain more detail?
(‘invoke a URL’ means ‘implements HTTP client with DNS client’ ?)
Regards,
Eric.
RE: Invoke a URL
by koldiodo ·
Hi Eric:
I would like to send some values calculated inside the program, to a webpage on the net through a webform on that external page. So I need to periodically invoke something like this: “http://webpage_url/formresponse?entry1=value1&entry2=value2”(value1 and value2 are known, calculated inside the code).
I don’t think the complete HTTP client is needed, because I don’t need to process the answer of that URL.
I hope it’s clear now.
Thanks!
RE: Invoke a URL
I guess, that function would be possible to performed on WIZ200WEB board.
You have to implement your function by referring to the WIZ200WEB source code.
Regards,
Eric.
RE: Invoke a URL
Please refer to WIZ200WEB webpage example.
The ‘Analog Input’ page shows analog input data on webpage when a certain condition happens(data changes, Ajax),
and ‘Digital Input’ and ‘Temperature Read’ page shows data on webpage periodically(webpage refresh using HTML meta tag).
Remember, If you want to implement a specific web function, need modify both of the source code and webpage code.
Regards,
Eric.
