Device Configuration through a power cycle
RE: Device Configuration through a power cycle
by ssekim ·
You can do it using <AT&W0> command.
Most configuration items would be saved.
Please refer to the .
(AT&W, AT&V, AT&F)
Steve
by HEN ·
Hi Steve,
by ssekim ·
Hi Hen
All options which you can see with <AT&V> are saved.
Steve
by HEN ·
Hi Steve,
by ssekim ·
Hi HEN
Yes, you’re right.
But, you can change with AT&Y.
AT&Y0 : Set default configuration to profile #0
AT&Y1 : Set default configuration to profile #1
wiznet.co.kr/Admin_Root/UpLoad_F … _V130E.pdf
Steve
by HEN ·
Hi Steve,
I send the following commands to the device -
AT+WD
AT+WM=2
AT+WAUTH=0
AT+NDHCP=0
AT+NSET=192.168.55.20,255.255.255.0,192.168.55.20
AT+WSEC=1
AT+DHCPSRVR=1
AT+WA=LimitedAP,8,
AT+NAUTO=1,1,5000
AT&W0
AT&Y0
When I issue a AT&V to check the configs I get the following -
ACTIVE PROFILE
C1 &Y0 E1 V1 B=115200,8,N,1 &K0 &R0
+NDHCP=0 +NSET=192.168.55.20,255.255.255.0,192.168.55.20
+DNS1=0.0.0.0, +DNS2=0.0.0.0
+WM=2 +WAUTO=0,“WizFiAP”,
+WRETRY=5 +WP=0 +WRXPS=0 +WRXACTIVE=1
+NAUTO=1,1,0.0.0.0,5000
+WAUTH=0 +WWPA=“”+PSK-valid=0 +SSID=
+WWEP1=0000000000 +WWEP2= +WWEP3= +WWEP4=
+WEAPCONF=13,26,
S0=01000 S1=00500 S2=00500 S3=00003 S4=00010 S5=00150
+BDATA=0 +WSEC=1
+XEB=0 +XE2B=27 +XDUM=1 +XEHT=2,1,0,3 +XAIRCMDPORT=5001
+XDO=0,0,0 +XAR=0 +XUAP=0 +XPSO=0,0
STORED PROFILE 0
+WEAPCONF=13,26,
+BDATA=0 +WSEC=1
(Left Profile 1 out of this listing).
The Active and Profile 0, reflect some of the parameters that have been changed by my series of commands. However not all parameters appear to have been changed, for instance, nowhere in the profiles is listed the text “LimitedAP”, which I would have expected.
If I issue ATA2, then the device configures itself as a limited AP and I can connect to it.
If I power cycle the device and then issue an ATA2, the device does not go into Limited AP mode, suggesting the configurations have not been saved so that the device can be brought up in limited AP mode.
Could you please point out my mistakes?
by ssekim ·
Hello Hen
I just tested the below 3 cases.
(1) using ATA, not saved configuration(profile) and need to issue the below commands at every booting time
AT+WD
[OK]
AT+NDHCP=0
[OK]
AT+NSET=192.168.55.1,255.255.255.0,192.168.55.1
[OK]
AT+WAUTO=2,xxxxx,0
[OK]
AT+NAUTO=1,1,4000
[OK]
ATA
IP SubNet Gateway
192.168.55.1: 255.255.255.0: 192.168.55.1
[OK]
(2) using ATA2, not saved configuration(profile) and need to issue the below commands at every booting time
AT+WD
[OK]
AT+WM=2
[OK]
AT+WAUTH=0
[OK]
AT+DHCPSRVR=0
[OK]
AT+WD
[OK]
AT+WM=2
[OK]
AT+WAUTH=0
[OK]
AT+NDHCP=0
[OK]
[OK]
AT+DHCPSRVR=1
[OK]
AT+WA=xxxxx,8
IP SubNet Gateway
[OK]
AT+NAUTO=1,1,4000
[OK]
ATA2
[OK]
(3) saved configuration(profile) and the below commands need to be issued just one time.
AT+WD
[OK]
AT+NDHCP=0
[OK]
[OK]
AT+WAUTO=2,xxxxx,0
[OK]
AT+NAUTO=1,1,4000
[OK]
ATC1
[OK]
AT&W0
[OK]
AT&Y0
[OK]
Now, WizFi210 run in Limited AP mode automatically at every booting time.
Steve
by HEN ·
Hi Steve,
