Lost Configuration Access To WizFi630 Module
RE: Lost Configuration Access To WizFi630 Module
by kaizen ·
Dear jkellar
That may or may not be factory default, I think that It did not change factory default.
Because, If it is set factory default, It’s IP Address is 192.168.16.254. But you can’t access to this address.
For connecting configuration web page of WizFi630, You have to know it’s IP Address.
This is method for finding WizFi630’s IP address.
And then, start Wizard tool and click the find button. If it is success, you can find WizFi630’s IP address in this tool.
connect serial cable between WizFi630 and your PC. And then If you input command using terminal program as “Hyper Terminal”, WizFi630 return it’s IP address to your terminal program.
If you want to set factory default, you can use command. It is WizFi630’s factory default command.
input command
Wizard.zip (57.7 KB)
