Config tool does not find all wiz107 devices
RE: Config tool does not find all wiz107 devices
by jbkim ·
Sorry for inconvenience.
We’re now checking this problem & debugging the config-tool and get back to you soon.
by ywkwon ·
I attached test version of configuration tool. It is ver. 1.4.4.2.
Please confirm the test version.
If you face same problem with new version, please write a post.
[attachment=0]ConfigTool107_install_v1.4.4.2.zip[/attachment]
by micom ·
Hi Wiznet
This new version now finds a lot more devices. (I’m not sure how many there are, maybe all of them)
What did you change in the code?
by ywkwon ·
I have modified socket buffer size. It is increased the buffer size from 8K to 200K.
In case of 8K, socket can receive packets less than 24 at the same time.
Because the size of configuration message is 338 Bytes.
The packets are received at little different time, So It can receive some more.
In case of 200K, socket can receive packets less than 605 at the same time.
