Quick Start with AVR xMega256 and W5200
RE: Quick Start with AVR xMega256 and W5200
Hi, Marc007.
Firmware in our web is SPI.
So you can use it.
[url]https://www.wiznet.co.kr:8011/Sub_Modules/en/product/product_detail.asp?Refid=642&page=1&cate1=5&cate2=7&cate3=56&pid=1144&cType=2[/url]
Best regards.
by Marc007 ·
thanks for your answer. But your link doesn’t work.
Just an additional question. In your code examples I saw that the MAC address for the W5200 must be set manually. Do you know from where we can get the MAC addresses? We only need a small number (100…1000) of addresses.
Marc
by Marc007 ·
[quote=“hjjeon0608”]Hi, Marc007.
So you can use it.
Best regards.[/quote]
thanks for your reply, but unfortunately your link doesn’t work. I downloaded the example code for AVR indirect bus mode (see link below). Can I use this code also for SPI Mode when I Change the define #define DEF_IINCHIP_BUS DEF_IINCHIP_SPI_MODE? Or is this code only for indirect bus mode?
[url]http://www.wiznet.co.kr/sub_modules/en/product/product_detail.asp?Refid=634&page=1&cate1=5&cate2=7&cate3=56&pid=1144&cType=2[/url]
Thanks
Marc
Hi, Marc007.
You can download example code at our web > Product > TCP/IP Chip > W5200 > Download tap > W5200 Firmware.
And you should purchase the MAC address to be used in your system at the IEEE(www.ieee.org).
Best regards.
