Starting with WIZ610io in Arduino IDE
RE: Starting with WIZ610io in Arduino IDE
by taylor ·
Hello Mageric,
You can use the WIZnet Modified Ethernet library instead an official Ethernet library.
URL : https://github.com/Wiznet/Ethernet/wiki
If you want to use IPv6, this is a good reference. But some Arduino boards are not enough memory to run IPv6.
URL : https://github.com/Wiznet/Ethernet/wiki/W6100-IPv6
BR,
by NUK ·
I have Arduino MKR Zero Board and W6100 MKR- Ethernet Shield. I am interfacing both using SPI connections and using Latest Wiznet Ethernet Library but I am unable to ping the Ethernet Shield. I am using MOSI, MISO, SCK and CS pin too. What Ethernet Library should I use for W6100 if there is any? Please guide.
Regards,
Najeeb
