Using Sn_IR RECV bit instead of Sn_RX_RSR
RE: Using Sn_IR RECV bit instead of Sn_RX_RSR
Hi, ags.
W5100 and W5200 are same structure. So receiving process should be same.
And when receive data if you do not process prior received data, Sn_IR(recv) isn’t set as 1 after clearing Sn_IR(recv) bit automatically. It is overlapped.
So, we recommend using Sn_IR and Sn_RX_RSR both.
Best regards.
