[From QnA] Searching WIZ1000 doesn't work
RE: [From QnA] Searching WIZ1000 doesn't work
by ywkwon ·
Dear customer,
Thanks for your interest WIZ1000.
If you cannot communicate with WIZ1000 even you can configure it, please try ping test.
If you success the ping test, you can communicate with the WIZ1000. So you should check the parameter settings such as operation mode, serial settings, other options and so on.
But if you fail the ping test, that means your PC cannot connect to WIZ1000. Then you should check network settings such as IP(default local IP : 192.168.11.133), GW address, subnet mask and so on.
And please let us know your test environment serial settings, network settings and other options to analyze your problem.
Thanks,
WIZnet
