[From QnA]WIZ830 problem with TX memory allocation
IO Modules
IO Modules
RE: [From QnA]WIZ830 problem with TX memory allocation
by wiznetmuseum ·
Thank you for using our products.
You may refering the W5300 driver v1.2.1 for your application.
To use the TX memory on W5300, just assign the memory size and type writing TMSR, RMSR and MTYPEER.
If you cannot use TX memory even you have set right value to TMSR, RMSR and MTYPER, check your code which get the free size of TX memory.
Refer to the getSn_TX_FSR() function in the W5300.c of W5300 driver v1.2.1.
by wiznetmuseum ·
Solved!
I’ve checked my code… as you said: I read in wrong way the Sn_TX_FSR register (only the first word)
Many, many, thanks again!
Best regards
