[From QnA]ping failed 3150+88e1111
RE: [From QnA]ping failed 3150+88e1111
Dear customer,
Thanks for your interest in w3150A+
Please follow as below.
“1) Chip_init():- s/w reset the chip then select the mode of the chip direct or indirect mode etc.
2) Set the Address :- Like MAC Address, GATEWAY Address, SubnetMask and IP Address
3) Set RCR
4) Sysinit():- Set the Tx & Rx buffer size
5) Sock_init():- Create a Socket as per client and Server
6) Then infinite loop :- Do the action as per the socket STATUS like ESTABLISHED, WAIT or CLOSE etc.
7) Yes you can use ping to check the connections between PC and the module.”
If you hardware is correctly designed, the ping should be avialable after step 4. Is inturrupt signal assered after step 4? Please check if socket status is SOCK_INIT after step 5.
Thanks,
WIZnet
