CLI Config Tool Can't Do Anything But Search
- W7500
RE: CLI Config Tool Can't Do Anything But Search
by Grace_Koo WIZnet ·
To use this CLI Config Tool, your device needs to be running the WIZ750SR firmware.
Could you please let us know which firmware version your board is currently using?
RE: RE: CLI Config Tool Can't Do Anything But Search
by Justin ·
I'm using
WIZ750SR-1xxv129_incl_Boot.bin
I also tried with a part that was bought pre-programmed (W7500-S2E), which has version 1.2.3. It has the same result.
by Justin ·
I tested this as well with an evaluation board and had the same result. WIZ750SR-105 v1.0
PS C:\Users\JustinButtelmann\Desktop\DoppSpaceProto Testing\GPSDO\WIZnet-S2E-Tool-master\WIZnet-S2E-Tool-master> python wizconfig.py -s
Device configuration start...
Searching device...
Target: All
[Result] 4 device(s) detected.
* Device 1: BE:CF:8D:0E:42:EE [WIZ750SR-1xx] | 10.1.135.85 | OPEN | Version: 1.2.9
* Device 2: 00:08:DC:77:A5:65 [WIZ750SR-1xx] | 10.1.135.86 | OPEN | Version: 1.3.3
New Device: 00:08:DC:77:A5:65
* Device 3: 00:08:DC:55:D3:5E [WIZ750SR] | 10.1.135.84 | CONNECT | Version: 1.2.3
* Device 4: 00:08:DC:55:D3:72 [WIZ750SR-1xx] | 10.1.135.83 | OPEN | Version: 1.2.3
Check ''mac_list.txt'' file for a list of searched devices.
@ The file will be used when multi-device configuration.
PS C:\Users\JustinButtelmann\Desktop\DoppSpaceProto Testing\GPSDO\WIZnet-S2E-Tool-master\WIZnet-S2E-Tool-master> python wizconfig.py -d 00:08:DC:77:A5:65 --ip 10.1.135.87
Invalid Mac address!
