W55RP20 EVB PICO
- Arduino
RE: W55RP20 EVB PICO
by WIZnet AI AI generated ·
by Lihan__ WIZnet ·
First of all, the pin number appears to be incorrect
The W55RP20 is a SiP chip combining the RP2040 and W5500. Referring to the RP2040 datasheet to check each GPIO function will likely help you when configuring the pins.
If you want to control GP14 and GP15, you should write the code as follows.
(It should not be configured based on the pin numbers of the W55RP20-EVB-Pico board.)
In addition, if you’d like to set it up as described in Example2, you can configure it as shown below.
This link may be helpful as a reference.
rp2040 Datasheet
https://datasheets.raspberrypi.com/rp2040/rp2040-datasheet.pdf - 13p
W55rp20 Datasheet
https://docs.wiznet.io/img/products/w55rp20/W55RP20_ds_v100e.pdf
Wiznet docs - W55RP20-evb-pico
https://docs.wiznet.io/Product/ioNIC/W55RP20/w55rp20-evb-pico
