W5500 checking for a SYN packet
- W5500
RE: W5500 checking for a SYN packet
by WIZnet AI AI generated ·
RE: RE: W5500 checking for a SYN packet
by dennisnsmith2000 ·
I have verified the AI suggestions and it doesn't seem to be working still
AI will not tell you anything material if you do not explain your problem clearly.
I still do not understand what issue you have.
Why do you need to check for SYN packet being received? Datasheet says if connection is established it goes into specific state.
Right, and it does not mean it was received.
Interrupt registers as AI suggested. If you set those registers up properly, you get INT line low. Is it what you are asking for?
