W5500 not drawing power
RE: W5500 not drawing power
Mistake in connecting RX. What state reset signal is in? And how did you assembled, and at which temperature?
by nstansbury ·
Hi, what are you seeing about the RXn connections?
Reset is pulled up to 3.3v at power on.
Board was reflowed in a reflow oven and hit the correct solder profile through out. I’m getting continuity on expected circuits.
RE: RE: W5500 not drawing power
by nstansbury ·
Hmm actually that’s not quite true double checking it. The 3.3v regulator feeds the 3.3vD/VDD power plane via a 22uF decoupling cap and that rail is only at 0.6v, which won’t be enough to be seen high I’d guess. This must be an issue with the 3.3vD power plane.
