W7500 SPI Slave모드 질문합니다.
RE: W7500 SPI Slave모드 질문합니다.
by TheoIm WIZnet ·
안녕하세요, WIZnet Theo입니다.
아래는 제가 Slave 모드를 W7500 코드를 이용해 구현한 코드입니다.
정상적으로 수신 동작을 확인한 코드여서 한 번 사용해보시고 동일한 증상이 있는지 알려주세요.
/* Includes ------------------------------------------------------------------*/
#include “main.h”
#include “w7500x_ssp.h”
/* Private function prototypes -----------------------------------------------/
void delay_ms(__IO uint32_t nCount);
static void UART_Config(void);
void SSP1_Slave_Init(void);
/ Private functions ---------------------------------------------------------*/
@brief Main Function
int main()
uint16_t slaveRxData = 0;
/* Set Systme init */
SystemInit();
UART_Config();
printf(“W7500x Standard Peripheral Library version : %d.%d.%d\r\n”, __W7500X_STDPERIPH_VERSION_MAIN, __W7500X_STDPERIPH_VERSION_SUB1, __W7500X_STDPERIPH_VERSION_SUB2);
printf(“SourceClock : %d\r\n”, (int) GetSourceClock());
printf(“SystemClock : %d\r\n”, (int) GetSystemClock());
SSP1_Slave_Init();
int i = 0;
for(i=0; i<5000;i++){
while(SSP_GetFlagStatus(SSP1, SSP_FLAG_RNE) == RESET);
slaveRxData = SSP_ReceiveData(SSP1);
printf(“slaveRxData: %#04x\r\n”, slaveRxData);
volatile uint32_t delay = nCount * 2500; // approximate loops per ms at 24 MHz, Debug config
for(; delay != 0; delay–)
__NOP();
void SSP1_Slave_Init(void) {
SSP_InitTypeDef SSP_InitStructure;
<SSP1 PORT & PIN NUMBER>
- SSP1 SSEL (PB.00) Pin
- SSP1 SCLK (PB.01) Pin
- SSP1 MISO (PB.02) Pin
- SSP1 MOSI (PB.03) Pin
UART_InitTypeDef UART_InitStructure;
#if defined (USE_WIZWIKI_W7500_EVAL)
UART_Init(UART1, &UART_InitStructure);
UART_Cmd(UART1, ENABLE);
#else
S_UART_Init(115200);
S_UART_Cmd(ENABLE);
#endif
#ifdef USE_FULL_ASSERT
@brief Reports the name of the source file and the source line number
@param file: pointer to the source file name
@param line: assert_param error line source number
@retval None
void assert_failed(uint8_t file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf(“Wrong parameters value: file %s on line %d\r\n”, file, line) */
/* Infinite loop */
while (1)
#endif
