Retransmission and RST before RTR timeout
RE: Retransmission and RST before RTR timeout
More troubleshooting is needed. As I understood your PC is a “server”. What your PC sees is receiving retransmission of the packet. It does not state who did the retransmission, it could be a switch on behalf of W5500. Connect PC and W5500 directly without any gateways and switches (putting them in same subnetwork of course) and try again.
by mwiz ·
PC and W5500 are on the same subnetwork, and are connected through a mirror port.
W5500 ------------ Ethernet Port Mirroring Switch --------- Switch ----------Router ------ Internet -----Server
PC ---------------------------^
So the PC sees everything the W5500 sends or receives.
Mary
RE: RE: Retransmission and RST before RTR timeout
This is severe assumption which may be dramatically wrong.
by mwiz ·
I found my problem: see W5500 gets TCP timeout even when peer has sent the ACK within timelimit (200 ms) - #2 by Eugeny
The retry_count, which sets the RCR register, must be 3 or greater. Less than 3 leads to ‘unpredictable’ behavior.
Wish that was in the data sheet.
