W7500S2E-build of unmodified source does not match
RE: W7500S2E-build of unmodified source does not match
by Aimee0 WIZnet ·
It seems like a review of the memory regions before building would be necessary.
To get the board back up and running smoothly, you could consider following these steps.
Upload W7500x_S2E_Production.bin file (Boot + App code) with ISP tool.
How to use ISP tool | WIZnet Document System
Manual : https://docs.wiznet.io/img/products/w7500/documents/appnote/w7500x_ispmanual_v100e_v2.pdf
connect with this pin in wiz750sr module
Reboot & search with Config Tool
And if you intend to update the firmware using the Configuration Tool, you should use the file Projects/S2E_App/bin/W7500x_S2E_App.bin (App code).
by fwj ·
Thank you for the response.
Yes the memory region settings match what you show above.
I did not modify any file or settings, I just unzipped WIZ750SR-master.zip and did a build in Projects\S2E_App.
I don’t have a WIZwiki-W7500P. I only have a WIZ750SR-485.
Is the problem that I should only load W7500x_S2E_App.bin with Config Tool?
In general, is it OK to use Config Tool to load W7500x_S2E_Production.bin?
RE: RE: W7500S2E-build of unmodified source does not match
by Aimee0 WIZnet ·
I have confirmed that both files match.
When you checked like this, do the files not match?
You can use ISP tool in WIZ750SR-485, without WIZwiki-W7500P.
1 . Connect with WIZ750SR-485 ↔ PC with uart to usb converter.
WIZ750SR-1.3.3/Projects/W7500x_S2E_Production.bin
→ This is boot + app code binary file. It can be load only ISP Tool.
WIZ750SR-1.3.3/Projects/S2E_App/bin/W7500x_S2E_App.bin
→ This is app code binary file. It can be load only Configuration Tool.
