W5500 - can't open socket
RE: W5500 - can't open socket
Would it be better to perform software reset and only then try reading the chip ID? I do not think it is much difference, but I would prefer this way.
Good question. Did you set up source MAC address, proper source IP address and mask? Anything in gateway address?
Datasheet does not say it will return back to 1 automatically. It says this bit must be set to 1 after setting it to 0 (for proper PHY operation).
RE: RE: W5500 - can't open socket
by NeoProg ·
Thanks for your reply!
Yes, i tried open socket after setup in src IP, mask, gateway and mac address correct values. Ping tool is working and W5500 asnwer on ping requests but socket doesn’t open. I try again and return with results.
I want to get IP & mask using DHCP. W5500 does not working with default src IP, mask, gateway (0x0000)?
Sounds like workflow problem. And you are right, MAC address must be sufficient.
Can you please set port number after setting Sn_MR to 2?
by NeoProg ·
Sorry, problem was in broken wires for demo board power supply. After resplace wires W5500 work correctly and i can open socket! I should have checked power using oscilloscope before search problem in code. I did school mistake again
Thanks for help, Eugeny. Have a nice day.
