How do I run Modbus TCP/IP on a W5500 Ethernet chip
RE: How do I run Modbus TCP/IP on a W5500 Ethernet chip
by Bohu-Tang ·
No one answered?
RE: RE: How do I run Modbus TCP/IP on a W5500 Ethernet chip
by Matthew ·
Sorry for late reply.
The example you are referring to is on the WIZnet Github. You might want to check out the link below.
GitHub - Wiznet/WIZ550S2E-Modbus: Serial to Ethernet Module based on W5500 & Cortex-M0
by Bohu-Tang ·
Dear Matthew
Thanks for your reply.I am using this file officially for the first time, I would like to ask how to use this file on github. I can’t open it on keil.
by Matthew ·
For these projects, you will be viewing them in the LPCXpresso IDE or MCUXpresso development environment, not Keil.
To do so in Keil, you will need to port the src file yourself.
The URL below is how to run the Firmware project in LPCXpresso IDE or MCUXpresso.
GitHub - Wiznet/WIZ550S2E: Serial to Ethernet Module based on W5500 & Cortex-M0
by Bohu-Tang ·
Thank you very much for your reply, which is very helpful to me
