header file keywords
RE: header file keywords
Hi @Sushma_N_S
Please refer to the link below.
RE: RE: header file keywords
by Sushma N S ·
I couldn’t initialize my WizFi module after connecting through Arduino Uno.
#include <WizFi360.h>
#include <WizFi360Server.h>
#ifndef HAVE_HWSERIAL1
#include “SoftwareSerial.h”
SoftwareSerial Serial1(0,1); // RX, TX
#endif
/* Baudrate */
//#define SERIAL_BAUDRATE 115200
//#define SERIAL1_BAUDRATE 115200
/* Wi-Fi info /
char ssid[] = “WizFi_Server”; // your network SSID (name)
char pass[] = "***"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio’s status
WiFiServer server(5000);
void setup()
// initialize serial for debugging
Serial.begin(115200);
// initialize serial for WizFi360 module
Serial1.begin(115200);
// initialize WizFi360 module
WiFi.init(&Serial1);
WiFi.beginAP(ssid, pass);
// attempt to connect to WiFi network
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status=WiFi.begin(ssid, pass);
Serial.println(“You’re connected to the network”);
printWifiStatus();
// start the web server on port 5000
server.begin();
void loop()
{ // listen for incoming clients
WiFiClient client = server.available();
if (client) {
Serial.println(“New client”);
void printWifiStatus()
// print the SSID of the network you’re attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield’s IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
I’m getting as:
[WizFi360] Initializing WizFi360 module
[WizFi360] >>> TIMEOUT >>>
[WizFi360] Cannot initialize WizFi360 module
[WizFi360] Failed to set AP mode WizFi_Server
Attempting to connect to WPA SSID: WizFi_Server
[WizFi360] Failed connecting to WizFi_Server
can I know how to pair two modules through Arduino Uno board using the SSID and Password in code.
Hi @Sushma_N_S
It seems that timeout occurs because the connection between Arduino UNO and WizFi360 is not normal.
Please check the connection between Arduino UNO and WizFi360.
Due to compatibility between Arduino UNO and WizFi360, it is recommended to use 9,600 baudrate instead of 115,200.
