W6100 having unstable link status
RE: W6100 having unstable link status
How the chip was soldered, and what was the soldering profile - graph and temperatures? Please explain as much detail as possible.
I have the only one explanation - chip picks up its own carrier, and most possibly it happens through transformer 3V3A connection. If you look at the reference schematic it says in the top left corner “as close to transformer 2, 7 pin as possible”. Its meaning is very unclear, and I believe it means these transformer pins must be connected to 3V3A as close as possible with as thick trace as possible to minimize crosstalk between TX and RX. On your board I see this possibility was not mitigated, with long thin 3V3A trace from the source and connection to the pins 2 and 7 of the transformer with decoupling capacitor relatively far away from them.
The USBLC6-2 chip may also give a crosstalk between the TX and RX channels. This chip is not present in the reference schematic, and chip’s datasheet does not detail its use for Ethernet, without any notes or explanations, only block diagram without complete reference schematic.
by kenhansen ·
Thanks Eugeny. We will investigate your surgestions once we receive the boards from manufacturer. We get back with update once that have been done.
Thank you so much for your input.
