W6100 stuck in wizphy_getphylink(). Not Linking
RE: W6100 stuck in wizphy_getphylink(). Not Linking
by WIZnet AI AI generated ·
by TheoIm WIZnet ·
You mentioned that the issue occurred after changing
PICO_BOARDfrom"pico"to"none". If you are using the RP2040, I don't see why you would need to change it to"none". Or is the firmware you are using your own custom firmware?It is important to check the following:
pico_sdk_init()is being called correctly.PICO_BOARD=noneis set.From what I see, it seems that an incorrect GPIO configuration is preventing the device from receiving the link signal.
If you share your
CMakeLists.txtfile, I can analyze it in more detail.Regards,
