WIZnet TLS example + W5500
RE: WIZnet TLS example + W5500
by lawrence WIZnet ·
Hello, @nogema
could you first check spi working?
we can check tls function after checking loopback or ethernet network with io module.
RE: RE: WIZnet TLS example + W5500
by nogema ·
I have already run the example HTTP successfuly. After all, I successed to run the handshake by changing the configuration in the config.h file in Drivers/TLS/mbedtls/include/mbedtls.
My issue now is my configuration only works for some website. I think the problem comes from the features of the public key but sometimes even with two websites with the same public key features (for example, RSA 2048), the handshake fails.
I think I have a lack of knowledge about the TLS protocol and I miss some parameters.
Regards,
Maxime
