[WIZnet-PICO-C example] UDP Server Example, debug print missing
RE: [WIZnet-PICO-C example] UDP Server Example, debug print missing
by norajohnson ·
I'm using a wiznet W6100 EVB Pico board and it should send and receive data on a multicast address however I'm not finding anythig that works correctly. These sections will guide you through a series of steps from configuring development environment to running ethernet examples using the WIZ net's ethernet ...Lots of example Ethernet projects available monkey type and just as easy to develop for as the STM32F401. Also,. > Due to the complexity of the signalling involved with ...This is the documentation for the Raspberry Pi Pico Arduino core, Arduino-Pico. Arduino-Pico is a community port of. Arduino to the RP2040 (Raspberry Pi ...
RE: RE: [WIZnet-PICO-C example] UDP Server Example, debug print missing
by Aimee0 WIZnet ·
If you enable
set(BOARD_NAME W6100_EVB_PICO)in the example from the following link, you will be able to run UDP multicast on the W6100-EVB-Pico.https://github.com/WIZnet-ioNIC/WIZnet-PICO-C/tree/main/examples/udp_multicast/udp_multicast_receiver
