W5500 stops working
RE: W5500 stops working
What is the value in PHYCFGR register when problem happens? Check 3V3A level.
Use scope to see that is going on the lanes (twisted pair) before transformer (on the pins of the network connector) and after transformer (at the input to the RX channel).
The problem could be PHY configuration issue (e.g. PHYCFGR[5:3]=110) or electrical problem with W5500 PHY not seeing input signal in the RX channel.
RE: RE: W5500 stops working
by MiD ·
Thank you very much for your fast response!
I think I was a little bit unclear, sorry about that.
I can’t get the register value when the problem appears, because I never know when it’s happening.
I just checked the PHYCFGR register and it returned 0xB8, so everything should be good.
It’s more like the “other side” (where the network is attached) dies.
The W5500 doesn’t even recognize a plugged-in ethernet-cable.
And as I said, the chip was already working but “died” all of a sudden.
Just print this register is a loop into the diagnostic output. And when you know it ‘died’ look at the output.
Died completely - you power off the system, power it on, and it does not work any more? Or is it back alive when you power cycle?
It will only recognize if its core works properly, its PHY works properly, and there’s incoming carrier in the RX channel.
by MiD ·
Completely, at least the network part. SPI is still working at the current board. Unfortunately I’m unable to test older defective units as the chips were already replaced.
There is no internal diagnostic output that is running on the MCU all the time. Funny thing is that the W5500 is in charge of providing some sort of diagnostic output for the MCU/system.
This means that the core/phy of our W5500 ‘died’, since there was no change in either hardware or software?
Did not see chips dying completely so far. Hard reset /power cycle usually cures the issue.
I suspect your circuit must be assessed - I would start with power and network connection. Can you share circuit diagram and board image? How chip is powered - can the issue come from power - what is the circuit diagram of the powering circuit (including filters)?
by MiD ·
As far as I know we were sticking to the recommended schematic. But I’ll need to ask our electronic engineers about that. I would like to take you up on your offer after I’ve returned from my vacation in the first week of october, if this is okay with you
Nevertheless thank you very much for your answers and help so far!
