WIZ750SR-110 does not save configuration
RE: WIZ750SR-110 does not save configuration
by TimKeck ·
I was able to recover from this by using W7500ISP:
select ISP->Dump->Data Dump from top menu bar
Edit resulting data_flash.bin with a Hex editor, insert MAC address staring at offset 0
Under Step 2 - Erase: Check Erase Data0 & Erase Data1then click Start Step 2
Under Step 5 – Select Binary FIle: select Binary File as edited data_flash.bin by using Browse button
Check Write DataFlash
Click Start Step 5
This was Version 1.0.0.1 of W7500 ISP Tool, file “W7500_ISP_20180731.exe”
I hope this helps someone else.
RE: RE: WIZ750SR-110 does not save configuration
Thanks for telling me a good way.
I will show you how to insert MAC using ISP tool.
You can check it out in the video below.
https://youtu.be/fvmAwa4m5PM
