W5100S UDP Sendto zero ip address
RE: W5100S UDP Sendto zero ip address
by lawrence WIZnet ·
Hi @erg144
I could not know exacty the value of your code with
If you want to handle UDP socket as multicast, you need to setup Sn_DHAR as multicat mac address.
please check the below flows:
// Multicast init
setSn_DHAR(socket_num, mac addr);
setSn_DIPR(socket_num, multicast addr);
setSn_DPORT(socket_num, multicast_port);
socket(socket_num, Sn_MR_UDP, sock_port, enable_multicast);
sendto(socket_num, buf, len, multicast_addr, multicast_port);
Thank you,
