W5100S-EVB-Pico DHCP example uses wrong MAC address
RE: W5100S-EVB-Pico DHCP example uses wrong MAC address
If I recall library reads address into the structure and writes it back into the chip, thus struct you set may be rewritten before it is used as you want. Therefore before using the chip you must explicitly call routine to set MAC address within the chip, not (only) set it in the structure. Dig into the library to find it out.
RE: RE: W5100S-EVB-Pico DHCP example uses wrong MAC address
by richw42 ·
Yes, I should have investigated before complaining.
I put my code to set the MAC address in g_net_info.mac after the call to wizchip_dhcp_init();
and things seem to be much better.
