How to use the Wizfi310_CON with an external antenna
RE: How to use the Wizfi310_CON with an external antenna
by RobertoGatti ·
Just plug the antenna and it will work.
RE: RE: How to use the Wizfi310_CON with an external antenna
by Carlos Gonzalez ·
I don’t mean that exactly. To be able to use the external antenna pin, you have to modify the board by soldering a resistor or capacitor, but it is not specified how to do it. I want to remove the SMA connector from the board and use the antenna pin from the PCB.
Thanks!
