W5500 Ethernet module
RE: W5500 Ethernet module
by teddy ·
Hello, is the communication protocol TCP or UDP? Given that there’s talk about 1460 bytes in Wireshark, it seems like it might be TCP. Did you use the IoLibrary? Did you register and use functions like spi read and write burst?
How did you configure the SPI settings in the STM? Did you use DMA?
When you checked the Wireshark packets, were 1800 bytes transmitted every 8ms, excluding any missing ones?
Was the 8ms timing checked and transmitted using a timer counter?
There is not enough information provided. There are many variables in the program, so please confirm.
