WIZ750SR-TTL does not work anymore
RE: WIZ750SR-TTL does not work anymore
I guess your module is damaged.
I don’t know the exact reason either.
If you send me your circuit, I can ask the hardware team to review it.
First of all I recommend that you rewrite the firmware.
Please refer to the isp tool link and the firmware file link.
https://wizwiki.net/wiki/lib/exe/fetch.php?media=products:wiz750sr:download:w7500_isp_20150401.zip
RE: RE: WIZ750SR-TTL does not work anymore
by RadioMCMLVI ·
Hello Becky,
Thanks for fast answer.
I found w7500_isp_20180731 and his wiki. I followed this procedure, uploaded boot + firmware 1.3.3.
The module works again but after exiting ISP mode and reset it the message ‘INPUT FIRST MAC?’ appears on terminal.
So after searching on your web page, I used the MAC Tool V20151127 to set the same MAC Address as before. The module works now perfectly.
Question: In my project, I reset the module on startup by using the ‘nReset’ pin. Could this be the reason of this issue?
Remark: It’s not the first case of this trouble. Becoming a first module from my dealer (Comet Electronics, Bulgaria) it was the same. They sent me another one with the same MAC Address and I sent back the faulty module. Today, I didn’t have any feedback about the problem.
Thanks for your support.
Regards.
Robert.
