INTn pin always high
RE: INTn pin always high
According to the code above, it is normal for an interrupt to occur.
First I want you to check if udp data receive is done.
Also, I wonder how the interrupt row is checked.
RE: RE: INTn pin always high
by murseloguzandic ·
Hello, here mine RX code part
Falling edge interrupt working at mcu side I have tested already.
Best regards.
Are you on this condition?
I can’t see the code to clear the interrupt, are you clearing it?
Yes code enter
if (getSn_IR(w5500.socketNumber) == 0x04).I can’t see any change on INTn pin. As I understand pin stays low until I clear interrupt. If pin fall, I will add clear interrupt.
What is the w5500.socketNumber ?
In your code it should be zero.
Yes, it’s zero. I’m taking messages on UDP no problem there.
