INTn pin is always high
RE: INTn pin is always high
by irinakim ·
Hi~
I couldn’t look your question and I’m so sorry.
You confirm the SIR and SIMR register in common register.
If you use the Socket number ‘0’…
The SIR and SIMR set up a bit ‘0’ as high(1).
If you didn’t set bit ‘0’ in the SIR and SIMR, INTn Pin isn’t operate.
thanks
EK
RE: RE: INTn pin is always high
by Shubham Dubey ·
HELLO I WANT W5500 REGISTER CONFIGURATION USING TCP/IP
