WizFi360 stopped working during MQTT
RE: WizFi360 stopped working during MQTT
Hello.
Can’t you input AT commands even after removing power supply and reconnecting?
by haricane00 ·
Hi Austin,
That is correct.
I cannot input AT command even after removing power supply and reconnecting.
I think the module is dead.
I am curious to know why a bad AT command has caused this?
Regards,
Hari
I did a test, but unfortunately, the problem you asked for was not found, so it is difficult to understand why it occurs.
Could you try typing AT command after typing ‘+++’ in the terminal program?
If it still doesn’t work, could you try again after updating the latest version(v1.1.1.7) firmware with UART0?
Best regards.
RE: RE: WizFi360 stopped working during MQTT
by haricane00 ·
Hi Austin,
I just tried to connect on uart 0 to do fw update.
No response. So looks like module is dead.
Will see if this happens again on next module.
Hari
